Flywheel removal help please
peter
" I'm overhauling a 4 hp J
" I'm overhauling a 4 hp Johnson, and I can't get the flywheel off. a little help please.
peter "
"Peter.... If you do not have
"Peter.... If you do not have the proper flywheel puller, the following should do the trick for you. Back the flywheel nut off to a point whereas it is flush with the top of the crankshaft threads. Apply leverage pressure to the bottom of the flywheel with a good size screwdriver or some other leverage tool. With that pressure applied, tap the top of the flywheel nut sharply a couple times. That should do it, however use caution that you do not damage the crankshaft threads.
Joe
