MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 4 of 4
  1. #1
    Default oil is leaking from around the
    oil is leaking from around the prop what coud be
    the problem. 1991 model 40hp
  2. #2
    Ken Denman's Avatar
    Ken Denman Guest
    Default The prop shaft seal is most li
    The prop shaft seal is most likely gone. The age of your motor would indicate from high wear activities such as running in sandy water or ingesting fishing line.
    It will need replacing.
  3. #3
    MERC FAN's Avatar
    MERC FAN Guest
    Default "The seal on the Prop Shaft is
    "The seal on the Prop Shaft is certainly a likely cause. However, before commencing any work, I suggest you consider the following: Sometimes engine exhaust and two stroke oil residue dripping down from the exhaust stack inside the column, can cause you to believe the gearbox seal is leaking.
    If the leaking oil is very dark in colour it is highly probable that it is exhaust residue.As a double check, loosen the lower gearbox drain screw, the oil that drips from there will be either a nice translucent looking colour or a whiteish opaque colour.
    If it is whiteish, it is indicating water has entered the gearbox through the worn seal and the internal gears turning at high speed have emulsified the oil with the water. If thats the case, you will need to have the seal replaced and the gearbox thoroughly flushed prior being refilled with fresh oil."
  4. #4
    Join Date
    Mar 2006
    Location
    Harrison, MI, U.S.A.
    Posts
    5
    Default "I had a similar problem with
    "I had a similar problem with my '95 Merc 40 h.p. 4 cylinder. gear oil leaking around the prop. I replaced the o-ring on the shaft carrier assembly but now after putting everything back together I don't have reverse anymore, just forward. Any clue as to what I did wrong? thanks in advance"
Similar Threads
  1. New prop shaft seal still leaks.
    By downwindtracker2 in forum Mercury Mariner Outboard Forum
    Last Post: 03-29-2010, 12:23 PM
  2. 1970 40hp 400 series merc prop slip
    By dewey26 in forum Mercury Mariner Outboard Archive
    Last Post: 05-06-2009, 12:34 PM
  3. Prop size 40hp
    By jerry in forum Honda Outboard Archive
    Last Post: 05-28-2008, 01:57 AM
  4. Best prop for 40hp mariner
    By bb1111 in forum Mercury Mariner Outboard Archive
    Last Post: 10-04-2007, 06:48 AM
  5. Please help with prop on 40hp merc
    By pritchettk in forum Mercury Mariner Outboard Archive
    Last Post: 07-31-2006, 10:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
