Best way to get lower unit seals out 90 150 hp
"Hey Kraig... The Diveshaft se
"Hey Kraig... The Diveshaft seal is located in the bearing housing under the water pump wear plate..Put the housing is a vise, and punch it out with a screw driver..The prop shaft seals are in the bearing carrier..there are 2 of them...Back to back..they also can be removed with a screw driver..reach down thru the carrier and punch the old seals out..."
