Page 2 of 2 FirstFirst 12
Results 31 to 33 of 33
  1. #31
    tom f's Avatar
    tom f Guest
    Default a wire rubbing against somethi
    a wire rubbing against something(metal)or frayd. a wire could be broke inside insulation giving an intermitten power failure orgetting a supply of power. just have to look at all wires and see if any frayd or rubbing against something. just a thought. had same problem on my car just jiggled wires till it died. it was a pickup in dist. wire broke internally.
  2. #32
    Join Date
    Feb 2006
    marshfield , ma, usa
    Default "that seems like the best advi
    "that seems like the best advice yet...i had an old omc electric shift out drive and it would sometimes pop out of gear..it was electrical all right and damn near impossible to find because the insulation on the wire looked fine but when i picked it up i noticed it sorta "drooped."... sure enuf ,the connection inside was nearly non existant"
  3. #33
    Eddie from Oregon's Avatar
    Eddie from Oregon Guest
    Default Did you check the switch in th
    Did you check the switch in the gear shift?
Similar Threads
  1. Replies: 2
    Last Post: 09-01-2010, 12:18 PM
  2. '1997 Volvo 4.3 I/O dies runs fine, but dies.
    By trebor-75 in forum Volvo Penta Gas Engine Forum
    Last Post: 08-16-2010, 10:31 AM
  3. Engine runs fine on muffs not in water
    By dabba in forum Johnson Evinrude Outboard Archive
    Last Post: 08-12-2009, 10:11 PM
  4. Engine runs fine at 10mph
    By Frank Vanderschaaf in forum Johnson Evinrude Outboard Archive
    Last Post: 09-16-2007, 06:49 PM
  5. b97 200 EFI Runs fine but Dies Out after 20 minutes
    By rwischhoverfranservcom in forum Mercury Mariner Outboard Archive
    Last Post: 07-04-2006, 10:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
