Results 1 to 3 of 3
  1. #1
    Join Date
    Feb 2006
    Location
    Combs, KY, USA
    Posts
    2
    Default I have a older 75 hp johnson m
    I have a older 75 hp johnson motor. It runs fine in a barrel and when I give it full throttle it runs strong. When I put it on the lake it starts fine but when I apply full throttle it bogs down and will not go to full throttle. Sometimes though it will but not very often. What is the source of my problem???????
  2. #2
    Join Date
    Feb 2006
    Location
    Combs, KY, USA
    Posts
    2
    Default The Johnson motor is a 78 75hp
    The Johnson motor is a 78 75hp stinger.
  3. #3
    Default "More than likely the carbs ne
    "More than likely the carbs need to be rebuilt. The high speed jets are clogged.. Took me 2 months to figure it out on my nieghbors 65hp rude(way before i found this site!!) doing the same thing you say yours is doing. spray cleaner will not work they have to be completely disassembled and cleaned thourghly.. Good luck and happy,safe boating."
Similar Threads
  1. 87 Johnson 60 HP missingno power at full throttle
    By muley99 in forum Johnson Evinrude Outboard Archive
    Last Post: 11-02-2009, 09:12 PM
  2. Replies: 2
    Last Post: 08-21-2009, 11:19 AM
  3. 1968 20 hp johnson doesnt have full power at full throttle
    By phillipramsey in forum Johnson Evinrude Outboard Archive
    Last Post: 07-04-2009, 11:01 AM
  4. 1974 85hp Johnson slow power and stalls at full throttle
    By Mark Hayes in forum Johnson Evinrude Outboard Archive
    Last Post: 04-10-2004, 11:06 AM
  5. 1975 Johnson 115 HP Looses power at Full throttle
    By roger in forum Outboard motors archive 2000-2004
    Last Post: 09-09-2001, 09:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
