Results 1 to 2 of 2
  1. #1
    Join Date
    Jan 2006
    Sydney, NSW, Australia
    Default "Hi guys I'm back again. I
    "Hi guys I'm back again. I have a LM318 which has behaved normally in the cooling system up until now. The motor has a closed cooling system using normal coolant.
    The boat is on a mooring about 140 miles from home so I only get to it every second weekend religiously.
    On arrival I immediately check fluid levels etc etc. The last two trips I have found the cooling system to be fully pressurised, and when taking the cap off, coolant sprays out over the motor even though it is cold ( ambient temp about 25 degrees ( centigrade ) and two weeks since the boat has been used.
    How can this be ? and why does it occur now and not in the past ? Has anyone had a similar experience or able to offer me some advice.
    Any and all replies will be sincerely appreciated."
  2. #2
    Join Date
    Jun 2005
    , RI, USA
    Default "G'day Raymond, At firs
    "G'day Raymond,
    At first I scratched my head when I read your post. Then I thought about it and realized there are compressed gasses in the cylinders and to a lesser extent in the exhaust. Hopefully that is not what is pressurizing your cooling system.
    I found these notes in a Mercuiser service bulleting online. Seems potenailly applicable to your situation.
    If the cooling system is prssurized, check for a head gasket leak or exhaust gases entering closed cooling system.
    If higher pressure is obtained than listed below, exhaust gases may exist in system.
    Coolant System Pressure
    800 RPM (idle) 6 PSI (41 kPa)
    3800 RPM (WOT) 20 PSI (137 kPa)
    Check the following if excessive pressure or gas bubbles are found.
    a. Head gasket leakage by making a compression test.
    b. Exhaust gases existing in the closed cooling system by using a combustion leak tester.
    NOTE: Snap-on Tools has combustion leak tester available for testing coolant for exhaust gases. (BlockCombustion Leak Tester P/N GA170B)
    Kits are available to measure the pressure at the heat exchanger cap.
    Good Luck,
Similar Threads
  1. Cooling system
    By todd_thompson in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-04-2009, 12:32 PM
  2. Pressure cap for cooling system
    By psotis in forum Volvo Penta Diesel
    Last Post: 05-16-2009, 09:08 AM
  3. Closed water cooling system verses a raw water cooling system
    By Dan Stephens in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 02-19-2008, 12:56 AM
  4. Cooling system
    By hoseman in forum Mercruiser Sterndrive Archive
    Last Post: 03-15-2007, 06:50 AM
  5. Converting Johnson pressure fuel system to pump system
    By tuner in forum Outboard motors archive 2000-2004
    Last Post: 04-22-2003, 10:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
