1986 150 Propeller SizePitch needed
rsh19904
"Hello All again,
Just boug
"Hello All again,
Just bought 1986 Yamaha 150 counter rotating w/o prop and have been Johnson man and now need to know the correct size and pitch of a prop for this motor?? Also,wanted to know if anyone knows of good place to buy one..saw e-bay and most were standard rotation. Counter rotation goes/spins to the left correct?? Also, my boat is 18' manatee bow rider about 2000 lbs for estimate weight purposes. Thanks for the help."
you will probably need a 19p y
you will probably need a 19p you can buy a counter merc wheel with hub kit and will fit just fine what pitch of prop was on you johnson?
shouldnt be to far off even though yamaha is the best outboard ever 150hp is 150hp yes to the LEFT COUNTERCLOCKWISE IN FWD GEAR
