MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 11 of 11
  1. #1
    Join Date
    Jan 2006
    Location
    Stratford, Connecticut,
    Posts
    61
    Default I am looking into a sea doo ut
    I am looking into a sea doo utopia with this power. Has anyone had any experience with this set up pros and cons. and what are the general maintenance of a jet system. Any help will be greatly appreciated
  2. #2
    Join Date
    Jan 2006
    Location
    cathlamet, wa , wakiakum
    Posts
    335
    Default the jet is an excellent system
    the jet is an excellent system the 200 optimax provides great power smooth running easy starting and is short lived.
  3. #3
    Default Shawn What did you mean by
    Shawn What did you mean by "and is short lived"
  4. #4
    Join Date
    Jan 2006
    Location
    Posts
    335
    Default they just dont seem to last an
    they just dont seem to last and when they break it is very expensive.on the other hand the 175 sportjet is almost bulletproof
  5. #5
    Default What kind of problems are typi
    What kind of problems are typical? Is this something I should stay away from? I dont want to get stuck with someone eles problems!
    In the middle of january i went to look at the boat. It is very clean and well maintend so I put a deposit on it. ( my friend has the same boat w/ 240 efi and has never had any problems) so I thought this would be and ok choice. Then on the net I have read about problems here and there about the 200hp. But nothing gives a disciption of the problems (ie: blown head gasket or strarter died) they just mention problems. So I am suposed to complete the sale this weekend and I am nervous.
    Is there any Symptoms of problems that can be seen in a test drive and basic inspection?
    thank you for you help
  6. #6
    Join Date
    Jan 2006
    Location
    Posts
    335
    Default the 240 is an old school motor
    the 240 is an old school motor same power head as 175 with injectors and a computer 175 is carb
    the 200 optimax is a direct injection motor power head is completely different than the proven 2.5l 175 and 240
  7. #7
    Default "shawn, so you cant tell me a
    "shawn,
    so you cant tell me anything bad about the 200 other than your opinion of you dont like it?"
  8. #8
    ssparky's Avatar
    ssparky Guest
    Default Some of the jet installations
    Some of the jet installations have had problems with the plastic drive gear for the oil injection pump. So check it out.
  9. #9
    Join Date
    Feb 2009
    Location
    Fenton, Michigan, U.S.
    Posts
    118
    Default "searay, The Mercury’s 200 HP
    "searay,
    The Mercury’s 200 HP Sportjet is based on Mercury’s 2.5l V6 block. The same block is used in the more powerful 240 HP EFI Sportjet (Electronic Fuel Injection) and the less powerful 175 HP Sportjet (Carbureted). Mercury offers all 3 possible induction systems for their Sportjets, DFI (Direct Fuel Injection), EFI (Electronic Fuel Injection) and Carbureted. The latter two however will be discontinued in 2006. This is unfortunate as the 240 HP Sportjet is a great, however thirsty, machine. Mercury will discontinue all Sportjets except for the Optimax DFI jets which come in 200 HP and 250 HP. The 250 HP Sportjet is based on the larger 3.0l block."
  10. #10
    mercuryman's Avatar
    mercuryman Guest
    Default "The 200 HP and up Optimax OUT
    "The 200 HP and up Optimax OUTBOARD motors did seem to have some issues when they came out. These motors did not use the 2.5l block. They had a new 3.0l block. It seems like this did not work out very well in the beginning. Depending who you believe there are different speculations out on this subject. It did seem that the first of these motors had a fair share of power heads problems. Reasons seemed to have been detonation and damage caused by broken sparkplugs.
    Why the 3.0l motors and not the 2.5l motors had problems is not easy to say, but it was most likely caused by the higher heat due to the higher power output of these motors."
  11. #11
    poker casino782's Avatar
    poker casino782 Guest
    Default "***** ****** [url=""]***** 63
    "***** ****** ***** 638"
Similar Threads
  1. 2001 mercury 150 hp optimax engine revs at inital start up
    By boloseng in forum Mercury Mariner Outboard Forum
    Last Post: 02-22-2010, 06:09 PM
  2. 2001 200HP Mercury Optimax Outboard compression questionHELP
    By cmone42 in forum Mercury Mariner Outboard Archive
    Last Post: 04-15-2008, 06:56 PM
  3. Priming oil pump on Mercury 200hp Optimax
    By Alan Thomson in forum Mercury Mariner Outboard Archive
    Last Post: 04-04-2007, 06:57 PM
  4. Optimax Mercs 200HP
    By Robert K in forum Mercury Mariner Outboard Archive
    Last Post: 07-30-2006, 02:40 PM
  5. 2001 mercury optimax 200hp
    By ed macado in forum Mercury Mariner Outboard Archive
    Last Post: 04-03-2004, 01:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
