1979 70HP Evinrude
kerrlake_jim
"I have a problem gettin my ol
"I have a problem gettin my old workhorse past just headway speed. It cuts out as the spark advance gets to the stop on the stator. All cylinders check 125# and spark jumps half inch. Starts and idles really well. Have rebuilt the fuel pump and didn't make difference. Also had lower unit and prop replaced. Need a few suggestions. Good engine,not afraid to invest a little bit to make it right. Thanks for your attention. jim"
"James.... If you're sayin
"James.... If you're saying that the engine bogs down as you apply throttle (and you're certain you have spark), in all probability the carburetors are somewhat fouled resulting in a fuel delivery restriction. In which case, remove, clean, and rebuild them."
