Results 1 to 2 of 2
    Jack Walsh's Avatar
    Jack Walsh Guest
    Default We have a Modern Wheel Drive G
    We have a Modern Wheel Drive Gear Box. The Gear #is A.15002/2 stbd; Gear Type 'R'; Size 4A; 1600 BHP; 900RPM; The Company Modern Wheel Drive is no longer in business. The buyers of the Company do not want to discuss gear boxes. We require such technical information as thrust pad clearences. Can anyone advise as to where such information can be obtained?
    Default Re: We have a Modern Wheel Drive G
    Quote Originally Posted by Jack Walsh View Post
    I was chief project engineer with MWD from 1966 - 75.
    The thrust bearing that your G/box includes was almost certainly supplied by Michell Bearings Ltd of Newcastle, UK and they can give you the clearances etc.
    MWD is absorbed by David Brown Gears (he of Aston Martin 'DB' fame) and although they probably know very little about your gearbox they should have all the original specs
  1. Modern electronic ignition in old 140
    By ants in forum Mercruiser Sterndrive Archive
    Last Post: 03-22-2009, 05:05 PM
  2. Stern drive does not turn with steering wheel
    By tknight72 in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 08-24-2008, 12:49 PM
  3. Drive gear to drive distributor missing teeth 89 bayliner 23l
    By wizard166 in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-17-2008, 02:38 PM
  4. 99 drive gear
    By brokewhilefixin in forum Johnson Evinrude Outboard Archive
    Last Post: 06-30-2008, 10:59 AM
  5. Early 283 drive gear
    By fgillard in forum Chris Craft Engine Forum
    Last Post: 04-10-2008, 07:25 AM
