" Lube lower unit on 35 Hp Big
" Lube lower unit on 35 Hp Big twin with 90 wt Hypoid oil, from NAPA. There is a plug in bottom of the gear foot. May be way underneath. there is also a plug up near the place where the lower unit attaches to the tower. remove the upper ( vent) plug. Have the spout of the hypoid oil bottle ready to put in the lower hole. Remove the lower plug and incert the nozzle. Squeeze the bottle to add oil till it overfows out the top vent. then remove nozzle and put in plug quickly so the oil does nor run back out. Use oil, not grease.
Correct fuel ratio is 1/2 pint of 30 wt 2 cycle oil to the gallon (16 to 1). NOT pre diluted oil , and not higher ratios. Don't use TCW II oil. If you can't find 30 wt two cycle oil use NON DILUTED TCW III. Dont think you can use 30,50 etc to one. It may work one or two times, but you are chancing throwing a rod.
Art DeKalb "
