MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 3 of 3
  1. #1
    Default "I've noticed a significan
    "I've noticed a significant leak in my 1995 185 Pro Team bass tracker. It looks like I have a couple rivets leaking. After taking my boat off the lake and parking it in my garage there are a couple of rivets that drip water. If I'm on the water for about an hour water will start to come up through the drains in the floor of the boat. Can rivets cause that big of leak and if so, how can fix the leaking rivets on my boat?
    Please help."
  2. #2
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,116
    Default "Mark, might get some better a
    "Mark, might get some better advice posting this under a misc topic further down.
    However, it's probably not the rivets themself causing the leak. Your boat is 13 years old and constant pounding on the hull can "loosen" the rivets leading to a bit of a gap which will let in water.
    If you can determine where the leak actually exists (water sometimes travels quite a ways along a seam before it drips off) you can drill out the loose rivets, seal the seam with a decent below waterline sealer and re-rivet them.
    Alternately, you may want to take the rig into a boat repair place that specializes in aluminum and let them give you an accessment.."
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  3. #3
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "your rivets are brazier head
    "your rivets are brazier head rivets, solid aluminum, and can be installed yourself with the right equipment. bucking bars for the shop head, and a rivet gun with the proper tool head for the machined head. no sealer is necessary when done correctly. To find the leaks, put the boat on the trailer, fill it with some water from the hose and check for leaks. mark the bad or missing rivet with a marker.
    http://www.vansairforce.net/articles...OnRiveting.htm"
Similar Threads
  1. Bass Tracker Tournament 17 w 48SPLcavitating
    By catfishguru in forum Johnson Evinrude Outboard Archive
    Last Post: 04-02-2009, 01:16 AM
  2. Sealant for Aluminum bass tracker
    By sat1425 in forum Mercury Mariner Outboard Archive
    Last Post: 09-12-2008, 02:45 PM
  3. Leaking 95 Bass Tracker
    By marks_issue in forum Miscellaneous marine engine topics
    Last Post: 07-12-2008, 09:32 AM
  4. Bass Tracker with Force Motor need help
    By tsyschas in forum Chrysler Force Outboard Archive
    Last Post: 04-12-2008, 10:00 PM
  5. Mounting a motor on my bass boat
    By Ron Potts in forum Archive 2003-2009
    Last Post: 04-15-2004, 07:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
