rod_stewart
Outstanding Contributor
"Rick;
PN 29 is definitely th
"Rick;
PN 29 is definitely the water inlet hose from the drive. If you have PS, the cooler would be a suspect for plugging.
Please let us know how your backflush test of that hose goes.
Water will not flow by gravity out the manifold, as it must go up and over the riser/elbow. You should however be able to rig your garden hose up to it and get it to flow through under a little pressure. That is a test I would also do so as to rule out a blockage in that area.
Rod
Rod"
"Rick;
Rod
Rod"
