P
PPBBSS
Guest
"On my 1990 Johnson 110, I not
"On my 1990 Johnson 110, I noticed I only have 2 wires coming off the horn. Should I have 3 ? My schematic shows three. If the system is woking correctly, the horn should go off when I turn on the key,,Right? Also, I should be able to ground out the TAN wire and sound horn, I'm told. What if I wanted to hook up an "idoit Lamp" in the dash. Could I tap into the wiring some where to do so? Thanks guys."
