captainsharon
"Brand new to this site, sorry
"Brand new to this site, sorry if this is lengthy. Am I the only female? I last used this boat in August ran fine, flushed and left sitting since. Would not start, charged batteries, found severely corroded ground wire from battery to motor. Replaced both wires to motor. Still would not start, sylenoid seemed to work, but nothing from the starter. Bought new starter and connected. At first it would spin without engaging. First time it engaged for 2 seconds and stopped. Now nothing when turning key to start. My starter does not have the bendix on the shaft, it has a gear reduction drive that is only accessible when you take off the plastic fly wheel cover. So I reluctantly removed the covers and exposed the gears and flywheel. The bendix appears to be in working order but the flywheel will not turn by hand. Is this normal? I think that the bendix is rising and engaging but unable to turn the flywheel. Is it possible to seize from just sitting for 8 months. I live in South Florida it is hot and humid but no chance of freeze. I am mechanical and handy and enjoy learning. I am trying to decide when to call the mechanic. My starter is a looper or the motor is a looper. Maybe someone can explain what that is. I have a Seloc mannual but my motor seems to be the exception to every rule. Let me know if you can help."
