P
P Sheb
Guest
"Hello,
great site and have b
"Hello,
great site and have been reading alot. my problem is I went out on the lake today and motor died. had to keep priming the engine just to get back to the launch. as I was taking carbs apart to clean I noticed milky substance coming from exhaust, pulled prop and found wire line fwd of prop & shaft has slight play. do I need new seals or is it because I had to keep choking eng to get back? Also I have noticed alot of people writing about loss of power but will run at trolling speed all day long-that was my issue last time out until today when as soon as I went above 6 mph eng died as stated. I had just replaced plugs, put new gas in. I have not did compression check yet but I am going to. The carbs looked fine. Eng restarted and ran at idle fine after carb cleaning. Need some help please!
Paul"
"Hello,
Paul"
