Results 1 to 4 of 4
    Default I have a 1972 Wards Sea King w
    I have a 1972 Wards Sea King with a 35hp engine maufactured by montgomerey wards the
    Model # VWB27035A 17X Serial # 20465
    The engine sounds like it runs great it starts right up but the problem is I dont know why theres no water pumping through. The engine will start getting hot so I dont let it run too long but theres a clear hose that fluid maybe run through and nothing is flowing through there. So I want to knw what I should do I was told the water impeller may be bad but where is that located and how do i fix it?
    Jan 2008
    black creek , ga,
    180
    Default first of all it would help to
    first of all it would help to find a repair manual. try ebay. your impellor is located in the leg and requires removal of the foot. you might also find an impellor on ebay as well or browse the net and see. its normally not hard to replace.the clear hose depends on where it starts from and does it look like it might come from the block and be the water discharge ( pee ) hose? getting a repair manual will solve a majority of your ?'s
    Every day is a new day.....GO FISHIN
    Scott
    Default I havent gone and buy the manu
    I havent gone and buy the manual and the hose running through comes from the block where the spark plugs are so that would be the block. so thats the pee hose? Well Ill try the manual thing first and see from there thanks
    May 2007
    Inverary, Ontario, Canada - The Great White North Eh!
    9,127
    Default Your motor is a 1970 Chrysler
    Your motor is a 1970 Chrysler built for Wards. A Chrysler manual should provide you with all the info you need....
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  1. Bought the boat, no plug, boat filled w/ water. Now what? 1985 aq125
    By sonnyny in forum Volvo Penta Gas Engine Forum
    Last Post: 06-05-2010, 11:24 AM
  2. 2 year old 50 HP 2 stroke Ibm a newby to this board and any boat bigger than a jon boat
    By poordueto401k in forum Mercury Mariner Outboard Archive
    Last Post: 12-30-2008, 12:26 AM
  3. Replies: 5
    Last Post: 08-23-2008, 01:27 PM
  4. New boat
    By scott_h in forum Mercruiser Sterndrive Archive
    Last Post: 06-26-2008, 11:17 AM
  5. Possible new boat
    By will c in forum Mercruiser Sterndrive Archive
    Last Post: 05-02-2006, 07:23 AM
