Hynautic Reservalve problem
1
1983mainship
Guest
"I am working on a hynautic re
"I am working on a hynautic reservalve. When opening one of the purging screws, the screw sheared off. Anyone know if I can just replace this pin or do I have to replace the whole $550 unit? I was thinking about trying to drill it out or dremel out a flat spot for a screw driver. There is still a bit of it sticking out. HELP"
Got it. I used a dremel to cu
Got it. I used a dremel to cut a slot that could receive a flat head screw driver. I then backed the bolt out far enough to allow me to bleed the system.
