"I have a pair of TAMD40 in a
"I have a pair of TAMD40 in a 29ft Seabird 1983. After repairs they were started and ran on the block with no problems, although I never raised the speed to 3600 RPM. Once in the boat, the engines started, ran and idled with no problems. Port engine however will not run pass 2250 RPM. Starboard engine runs to 3600 RPM no problem. Turbo charger fine, new filters (fuel and air). At 2250 RPM slight vibration and misfire of injectors. I have new injector tips ready to be installed if necessary because I think that the injectors are causing the problem at higher speeds. Has anyone experienced the same problem?"
