98 honda 4stroke 8hp blue smoke
T
Tony Bushway
Guest
I have a 8hp stroke 1998. Whil
I have a 8hp stroke 1998. While running at trolling spedd 2mph. It evry now and then bogs down and emitts blue smoke. It then clears up and is fine for a while sometimes hours. Then it will do it again. Plugs have about 8 hours on them. Any ideas?
Thanks for the reply. I checke
Thanks for the reply. I checked and I have water in the oil. It looks like coffee creamer. When I had it serviced. They put too much oil in it and I ran it and had problems. They drained the oil and sent me back ou on the water. And know I have water in the oil. Headgasket??? Would too much iol in the crankcase blow the head gasket? If so what long term effects can i expect? Thank you In advance for your response.
Tony
"change the oil and run it agi
"change the oil and run it agian
it could be the powerhead gasket or head, or cracked block, or cracked head
a leakdowntest might find it"
