"If its noisy where you live,
"If its noisy where you live, then surely nobody will notice your outboard??? I hold a bucket over the prop to reduce noise.
Try the basic spark test, fuel disconnected, plugs not in heads but in plug caps and earthed on head, crank it over in the dark with old plugs and then the new ones, any not sparking???if one is not then you swap the plugs, did the missing spark move with the plug or stay where it was? If the plug is not at fault,swap the plug caps and see if the missing spark moves.
If the missing spark stays on the same cyl then swap the coils and see if it moves.
The above will cost you nothing to do and will keep you busy while waiting for the compression tester it will at least tell you if you have a missing spark and you just didn't notice it is running one cyl down....it can happen you know!
Good luck and keep us posted."
