DF70 flashing oil light no buzzer cranks and runs normal
J
Jason c
Guest
Is this the oil change reminde
Is this the oil change reminder or is it a pressure problem. The buzzer does not sound as the light flashes. The buzzer does sound during the initial start-up routine.
I purchased the boat used and
I purchased the boat used and it did not come with an owner's manual. Could you tell me how to reset the oil change reminder or give a link to the procedure.
Jason
pull out the ESS (emergenc
pull out the ESS (emergency stop switch) aka kill switch
turn key on
then pull the switch out 3 times within 7 seconds the alarm will beep when
reset
