How to check tachstator for 1995 Jhonson 115hp
johnson243
"Model J115eleo After replacin
"Model J115eleo After replacing rect/reg my rpm gauge doesn't read correct at idel (sits on zero and bounces) at full throttle needle swings around (5000 to 7000) motor runs fine... battery is charging 14.1 volts at 5200rpm. checked wires at motor and tach... the tach was doing this tail end of last season and than nothing on first trip this season(not charging either) I would like to check tach and stator.(got a feeling the stator started all this,is this possible???)"
"Don.... I'm aware that yo
"Don.... I'm aware that you've already replaced the regulator/rectifier assy BUT new doesn't always mean perfectly functionable. Do the below test to determine the quality of the tachometer, and a possible bad new regulator/rectifier assembly.
(Testing Tachometer With Water Cooled Regulator/Rectifier)
(J. Reeves)
A quick check is to simply plug in a another new tachometer as a piece of test equipment. If the new tach works properly and the old tach didn't, obviously the old tach is faulty.... but usually boaters don't carry around a spare tach (see below).
A faulty rectifier wouldn't damage the tachometer, the tachometer simply wouldn't work. This is due to the fact that the tachometer operates off of the charging system and the rectifier converts AC voltage to DC voltage, enabling the charging system. A faulty rectifier disables the charging system, and the tachometer simply doesn't register.
However.... those water cooled regulator/rectifiers that are used on the 35 ampere charging systems (and some others) bring into play a different type problem, and as you've probably found out, they are really a pain to troubleshoot via the proper procedure. There's an easier way.
The tachometer sending/receiving setup operates off of the gray wire at the tachometer. That same gray wire exists at the engine wiring harness which is connected to the engine electrical terminal strip. You'll see that there is a gray wire leading from the regulator/rectifier to that terminal strip, and that there is another gray wire attached to it. That other gray wire is the wire leading to the tachometer which is the one you're looking for.
Remove that gray wire that leads to the tachometer. Now, find the two (2) yellow wires leading from the stator to that terminal strip. Hopefully one of them is either yellow/gray or is connected to a yellow/gray wire at the terminal strip. If so, connect the gray wire you removed previously to that yellow/gray terminal. Start the engine and check the tachometers operation, and if the tachometer operates as it should, then the regulator/rectifier is faulty and will require replacing. If the tachometer is still faulty, replace the tachometer.
If neither of the yellow wires from the stator is yellow/gray, and neither is attached to a yellow/gray wire, then attach that gray tachometer wire to either yellow stator wire, then the other yellow wire, checking the tachometer operation on both connections.
I've found this method to be a quick and efficient way of finding out which component is faulty.... the tachometer or the regulator/rectifier. It sounds drawn out but really only takes a very short time to run through. If the water cooled regulator/rectifier proves to be faulty, don't put off replacing it as they have been known to catch on fire with disastrous consequences.
When time permits, visit my store at: http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store"
thanks for help Joe... I don&#
thanks for help Joe... I don't appear to have an engine elec. terminal strip. unless it's in the boat somewhere. anyway I got a tach from a friend and that one bounces too. So I guess I bought a bum part. Is there any chance the stator is causing this? the yellow wires you mentioned have a little tinge of brown at the plug end as if they got hot maybe.
It had not entered my mind tha
It had not entered my mind that possibly the terminal strip setup may have been eliminated in favor of a all plug in type setup on that 1995 115hp. I'll back out of here to let a more knowledageable tech that is familiar with the wiring circuitry enter their comments.
(Mort) When was the terminal strip setup eliminated?
"Eliminated with the introduct
"Eliminated with the introduction of the 60degree loopers 90/110, 150/175 with OIS ignition."
