Aq140a solex carb sync
v20
How do you attach a vaccuum ga
How do you attach a vaccuum gauge to the square side draft solex carbs on my aq140a? If they were a normal round carb it would be much easier.
El.. Is this the same unit to
El.. Is this the same unit to buy for the round carb on a AQ151 I have been looking for one of these thanks again TJ
"Yes, but you need to adapt it
"Yes, but you need to adapt it. According to Seloc an empty 3 lb coffee container makes a wonderful adapter for the Solex downdrafts."
I read the Seloc manual and sa
I read the Seloc manual and saw that but it seems to be refering to the round downdraft carbs not the square sidedraft units. Has anyone made something that works for the sidedraft carbs?
"Ted, I already said that the
"Ted, I already said that the Uni-Syn works like a charm in your type of carbs (Solex sidedraft). I have used it to synchronize the carbs in my previous boat, which had an AQ140. You just have to remove the flame arrestors in the carbs and hold the gauge directly against one carb at the time while keeping the gauge's tube vertical."
