FuelOil mix and spark plug setting for 1982 40hp mariner 2 cycle
willy47
Iam tring to find out the corr
Iam tring to find out the correct feul/oil and spark plug setting for this motor.I do not have a owners manual.I currently use a 50:1 F/O mix and spark setting of .25 is this correct? Any help would be greatly appreciated
"Bill, the 50:1 is perfect &#4
"Bill, the 50:1 is perfect (regular unleaded gas and TCW-3 rated Marine oil) and if you are using NGK plugs (B8HS is what the book calls for), the gap should be .024."
"Graham,
Thanks so much for t
"Graham,
Thanks so much for the info.I do use the NGK B8HS spark plug and will correct the gap.
Thanks again,
Bill"
