Using ears to start up engine
slik
When using the Ears should wa
When using the Ears should water be flowing from the pee hole while running or just when engine is submerged in the water? If so-mine doesnt-what are the cures?
"Force motors are real funny a
"Force motors are real funny about that. depending on the condition of your water pump or if the cooling ports on the motor are slightly clogged, you may get litle to none. When you give it a little fuel, it should produce water flow - not always a stream like other motors. I try to always use a garbage can or drum - just to be safe, the motor like a back-pressure of water to work best. At least that is what several mechanics have told me."
Thanks Brian-Last year when I
Thanks Brian-Last year when I took it out it was fine but I dont remember if the water came out with the ears or not-just wanted to be safe -Ill put it in on Thursday and check it out-Thanks
Gary
