Results 1 to 2 of 2
  1. #1
    Join Date
    Apr 2008
    Location
    usa
    Posts
    2
    Default "was told to get boat at top s
    "was told to get boat at top speed (after trimming out)and check rpm with handheld tachometer. i have a handheld tachometer (inductive) that will set for 6 cylinder, how do i calculate from 4stroke to 2stroke and get a accurate reading. 1988 evinrude 150 (im trying to determine which prop i need to run at the correct rpm"
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "From 4-stroke to 2-stroke div
    "From 4-stroke to 2-stroke divide the reading by 2.
    Read 5000rpm -running 2500 rpm. To make it work for You, the meeter must be able to read above 10.000 rpm!"
Similar Threads
  1. Tachometer ? 1980 90 hp
    By river rat in forum Mercury Mariner Outboard Forum
    Last Post: 06-25-2010, 08:53 AM
  2. New tachometer
    By rbarrow in forum Miscellaneous marine engine topics
    Last Post: 04-19-2009, 01:47 PM
  3. Tachometer
    By lefty in forum Mercruiser Sterndrive Archive
    Last Post: 08-28-2006, 07:55 AM
  4. How do i check and fix my tachometer
    By butler652merc in forum Mercury Mariner Outboard Archive
    Last Post: 06-18-2006, 10:51 PM
  5. I need a schematic for a 1996 system check tachometer
    By roger f in forum Johnson Evinrude Outboard Archive
    Last Post: 05-13-2006, 09:44 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
