Tohatsu
S
simon vowles
Guest
tohatsu 2stroke 6hp can it be
tohatsu 2stroke 6hp can it be converted to 9.8hp any help
can a 2stroke tohatsu 6hp be c
can a 2stroke tohatsu 6hp be converted to a 8hp
hi is there much differance be
hi is there much differance between 6hp 9.8hp 2stroke thanks
hi is there any other props wh
hi is there any other props what fit a 6hp thanks
Huge dfference and there 5 or
Huge dfference and there 5 or 6 different pitch propellers avaialable from any Nissan or Tohatsu dealer.
what is the best prop to go fo
what is the best prop to go for make the boat faster
hi tohatsu 6hp the number on m
hi tohatsu 6hp the number on my prop is f8.5 what is the next number up only the boat to go faster
Forget everything I told you e
Forget everything I told you earlier. Europe( in theory you are part of Europe) has different model configurations than the U.S. Your six is on the same frame as the 8 and can be altered to be an 8. You need the following carburetor parts to convert it:
1 of 3B2032520
1 OF 3B2032510
Then you can go to a 9 pitch prop.
HI ON EBAY PROP 7.8X8 WOULD TH
HI ON EBAY PROP 7.8X8 WOULD THAT BE ANY GOOD THANKS
