M
Mike Gulfcoast
Guest
"1999 150 HP
resevoir pump t
"1999 150 HP
resevoir pump tests o k with 12 volts applied.
manual override toggle switch does not work and tests o k
sending unit in secondary tank sends an alarm when tank runs low, but does not trigger the resevoir pump to operate. This leads me to believe the sender is bad, but not sure how to test it.
4 prong electrical jack at resevoir tests 12V with key on on the tan wire lead, but with sending unit on secondary tank in the low position, no other leads test hot???
Any information would be appreciated.
thanks Mike"
resevoir pump t
"1999 150 HP
thanks Mike"
