1958 18hp Evinrude Fastwin
You are turning the flywheel o
You are turning the flywheel or the prop while shifting?
"This is normal. The dog in th
"This is normal. The dog in the lower unit has 2 big square teeth. The gears have 2 big square teeth. The tops of the teeth hit, then the rotation will allow them to drop and mesh together. When the engine is running, It will fall right in."
is there an adjustment? I was
is there an adjustment? I was told when it was running didnt always shift. i received it partially apart could not run it.
