uniflite_27
"Hey guy's, I noticed that
"Hey guy's, I noticed that my oil seems a little high, I'm using 10w30 oil, the idle is set at 700 rpm , the pressure reads around 40 psi at a idle , if I give it more throttle ( 2000 rpm ) it sometimes as high as 80 psi,now when I do this it is just at the dock, haven't tried it while under load yet, not sure if that would have any bearing on it. The manual says it should be at 20 psi at a idle. Your thoughts on this would be outstanding.
Thanks very much,
Gerald."
Thanks very much,
Gerald."
