Pitot Speed indication
joshua3608
"Have a 2002 175HP V6 Series 2
"Have a 2002 175HP V6 Series 2 outboard, the Speed indicator on the digital speed gauge indicates a scored line " - ", i.e. no speed indciation.
The Pitot line is rigged to the back of the instrument and i followed it all the way to the cable loom entering the engine, from there i believe it is routed down the leg to a stainless steel pick up / split pin looking Pitot on the front of the leg.
What does the scoerd line " -" in the speed indication indicate ?, how do I fix it ?."
"Well have worked some of it o
"Well have worked some of it out myself, The Pitot tube on the leading edge of the leg was blocked, looked vey much like the previous owner hit a log ( pitot had wood splinters blocking it ).
Hopefully the speed indication will now work ?."
