1stboat
"I plan on adding a 1600 watt
"I plan on adding a 1600 watt amp a 700 watt power converter, a radio, and 8 speakers to my boat. I already have two batteries with a perko switch.
I was planning on getting a new 2 gauge ground wire running from the engine ground to a fuse block for the amp and converter. the power wire running straight from the battery, and getting a different fuse box, so i can use the other one for the engine.
What do you guys think about the set up? Any other things i should do? thanks."
