J
James Bell
Guest
"Hi guys, is it possible to do
"Hi guys, is it possible to do a bodged bypass of the switchbox, ie..couple of relays on the trigger, when the trigger pulses it activates the relay and allows the stator to power the coil,
I have tried every thing on this engine (2002 mercury 25hp seapro) and it will not spark/fire on No1 piston, compressions are good, it gets fuel, but no spark, going by the manual for testing the trigger, stator, they are ok, I dont want to spend £150 on a new switchbox if its not faulty.
This is a continueing problem from last year and I gave up on it over the winter, now its time for fixing it or using it as an expensive anchor,
I have replaced all gaskets and seals, checked the carb and the reeds,
Without use a dva adapter, I used a multimeter to check voltage from the switchbox to the coils and there is voltage, but I dont know how much as the meter reading is all over the place, maybe thats why we use dva adapters,
