Click for Honda Manuals, Parts and Model Guides!
Results 1 to 2 of 2
  1. #1
    Default "-----------------------------
    I have a Honda BF5A (5hp, 4 stroke) outboard. When I run the motor there is no water coming out from the top. I'm guessing this means the water pump is n"
  2. #2
    Join Date
    Apr 2007
    Location
    Seattle, WA,
    Posts
    897
    Default "I thought the same exact thin
    "I thought the same exact thing when I went to our local Honda dealership. I asked for a pump kit and some crusty old guy bellowed "Are you sure you need one!" I said, Well I dunno you tell me! So he takes me upstairs to the show room and takes the hood off a brand new 8 hp (mine is a 1986 7.5 hp) and I was shocked that it looked identical, nothing changed in 20 years! Anyway he showed me the tube that comes up from the water intake inside the casing and goes into the engine. He said take that off suck through it. If it's clogged then take compressed air and blow it out. Then follow the cooling hoses around the motor and do the same. And try and blow out the cooling jackets that go through the head as well. I did all that and voila! My motor was pissing like a racehorse. I didn't need a new impellor or did I have to take the motor apart. I take all my honda business to this guy. "
Similar Threads
  1. BF5A 5hp Honda no water
    By lbrad in forum Honda Outboard Forum
    Last Post: 02-20-2010, 02:27 PM
  2. Honda 15d water pump
    By gabriola in forum Honda Outboard Archive
    Last Post: 02-02-2009, 02:31 AM
  3. Honda BF5A with idle problems
    By hawksbill in forum Honda Outboard Archive
    Last Post: 06-27-2008, 11:11 PM
  4. 200 honda water pump
    By Joe Poulos in forum Honda Outboard Archive
    Last Post: 05-01-2008, 09:28 PM
  5. BF5A water impeller grommet Justintime
    By cosmosailer in forum Honda Outboard Archive
    Last Post: 03-13-2008, 11:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
