Water pump replacement
rudyr
"Graham,my red light comes on
"Graham,my red light comes on above 3000 rpms on my 60 horse merc,throttle back and it goes out fast.Run all day and won't miss a beat.Doesn't seem to run hot.Thanks Kyle"
"Fishman, drain the oil from t
"Fishman, drain the oil from the lower. if it's wet, you need a reseal. has nothing to do with pump. it's a good idea to pull the prop every year. grease the splines, and re-install."
