1995 force 120hp
david_67
hit a log last year ever since
hit a log last year ever since can not go over 10 or 11 mph took lower unit apart and replaced the cam shifter and it still does it need help
And you have checked ignition
And you have checked ignition timing and looked for a sheared flywheel key?????
"Or how about the prop itself
"Or how about the prop itself - it the hub did it's job (and slipped to prevent lower unit damage) may need a new hub....
Do the rpm's go up like normal, but just don't get speed? - that's a sign of a spun hub..."
motor takes off like normal un
motor takes off like normal until u get to 10 11 mph and then raps to 5000 rpm also with boat out of water u put in forward and turn the prop by hand it clicks but it does not do it in reverse
can someone tell me what the g
can someone tell me what the gas to oil ratio is on a 1998 120hp force.
good morn
can anyone tell me
good morn
can anyone tell me where I can get either the specs on or the owners manual for a 1998 angler 204 w/a
