Stuck needle valve
zephyr07
"I have a 1997 2 stroke 8 h.p.
"I have a 1997 2 stroke 8 h.p. Yamaha outboard. The motor is used infrequently to power an inflatable, and is unused for months at a time. I keep having trouble with a stuck needle valve. I even had the carburetor rebuilt, and it is still an issue. I always run the engine dry before storing it. I suspect that draining the carb bowl would solve the problem, but I can't find a drain plug for the carburetor. Is there a drain plug? Any other advice?
Thanks very much."
"Nelson, you may have to remov
"Nelson, you may have to remove the carb to drain it. You could try running fuel stablizer all the time, that helps prevent gumming..."
