Chrysler M440 Exhaust Manifold Bolts
lanikai34
Do the exhaust manifold bolts
Do the exhaust manifold bolts go into the head water jacket or do they bottom out in a closed hole? Replacing one of the manifolds and I don't want any wet surprises (drain engine cooling or not).
"I know on 360 and 318 the two
"I know on 360 and 318 the two end ones do go into the water pockets on the heads. I am not sure about a 440 though.
good luck, will"
"just did one of mine last fal
"just did one of mine last fall... i sugest buying the gasket kits with the bolts....just know also that the riser to manifold cap gaskets will probably be wrong....when i bought mine they were listed as the right thing but it was the same gasket as the end cap which is wrong for the riser side. i just made my own from some stuff i got at napa with metal in it.
http://img49.imageshack.us/my.php?image=pics005as1.jpg"]
url]
[/URL]"
