mrinvestor36
"I have a 97 200 Evinrude Vind
"I have a 97 200 Evinrude Vindicator. The engine at idle runs solid--checked compression and its good on all cylinders, but once you put it in gear you start to hear a knock that sounds like its in the engine. At idle you can hit the hot-foot and she sounds awesome, but once in gear and running across the lake you can hear the knock. The shop opened the block all cylindes look good "no scars on the walls" they want to (mic) the crank. They also told me it *could be* the crank bearing... Someone please help before I spend alot of money..."
