Results 1 to 10 of 10
  1. #1
    Join Date
    Jun 2007
    Location
    fairhope, alabama, usa
    Posts
    24
    Default "i just replaced my timer base
    "i just replaced my timer base, stator, rec.. my motor is running backwards. how do i correct this problem? evinrude 200 1998 also does the fly wheel[under the fly wheel nut] have to be flush with the crack shaft shoulder? i have used an impact and cant seem to get it down any more."
  2. #2
    Join Date
    Oct 2007
    Location
    Heidelberg, Southern Ontario, Canada
    Posts
    247
    Default How does it start running back
    How does it start running backwards? Is the starter motor spinning it backwards right from the beginning?
    Wrench
  3. #3
    Join Date
    Jun 2007
    Location
    Posts
    24
    Default it seems to backfire and the f
    it seems to backfire and the fly wheel turns in the oppsite direction. if you are looking at the motor from inside the boat the starter turns it clockwise and then it starts and chuggs and the fly wheel will be turning counter clockwise. when it does start up right it will being peeing and when it starts backwards it doesnt.
  4. #4
    london marine's Avatar
    london marine Guest
    Default Did you put the flywheel on in
    Did you put the flywheel on in the right place??? Is the flywheel key locating the flywheel properly?? Did you torque the flywheel nut???
  5. #5
    Join Date
    Jun 2007
    Location
    Posts
    24
    Default the flywheel key is in alignme
    the flywheel key is in alignment with shaft and flywheel. i have not used a torque on it yet. i was just concerned about the remaining distance that it looks like the fywheel has to go do. the flywhel nut will not seat on the shoulder on the crankshaft. does it need to be sitting on the shoulder?
  6. #6
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,212
    Default "The flywheel must absolutely
    "The flywheel must absolutely be torqued to factory specifications. ON that model, I believe iit is 145 foot pounds but check that figure.
    DO NOT use an impact wrench!
    I strongly suspect that you atrateed the engiine with having that flywheel nut torqued to less that factory specifications. This results in having the flywheel key shear, throwing the engine out of time. Usually this prevents the engine from running at all.
    However in your case I suspect that the flywheel has spun to a point where the timing is such that the ignition is being engaged in a reverse manner which would cause the engine to run backwards.
    Remove the flywheel. If the key is sheared even slightly, replace it with the proper part numbered key (not something from a hardware store), and torque the flywheel nut properly.
    Note that the flywheel and crankshaft tapers must be cleaned if scored etc. Have the flywheel key aligned straight up and down, not aligned with the crankshaft taper."
    We occasionally have questions. If you fail to answer, it may affect ours.
  7. #7
    Join Date
    Jun 2007
    Location
    Posts
    24
    Default i just took the flywheel off.
    i just took the flywheel off. the key looks good. the is no evindence of shearing. i did notice my crankshaft has a little play in it. is it normal to have some play there. if not then i need to change the bearing? thinking back over the wiring and i found something i am not sure of now is the powerpack wirning to the coils. should the blue trace wire be on the top coil or second coil? could this turn the motor in reverse?
  8. #8
    Join Date
    Jun 2007
    Location
    Posts
    24
    Default "there are some diodes on the
    "there are some diodes on the motor. what do they do? i know they allow dc volts to go one way but why are they there and if they are bad would this cause it? seems like if they are bad it would start. well.... maybe in reverse? i did have a major melt down. stator,rec.. and i just replaced the timer just in case."
  9. #9
    Default it has to be timing. check tim
    it has to be timing. check timing. verify trigger/stator was installed correctly. seems like you are getting spark way before tdc
  10. #10
    Join Date
    Feb 2001
    Location
    Posts
    14,212
    Default Orange/Blue = Top Plain Orang
    Orange/Blue = Top
    Plain Orange = Center
    Orange/Green = bottom
Similar Threads
  1. Hooked up battery backwards
    By mguerrieri in forum Mercruiser Sterndrive Forum
    Last Post: 07-15-2010, 12:22 AM
  2. Motor running backwards Anyone know
    By tony89evinrude in forum Johnson Evinrude Outboard Archive
    Last Post: 04-01-2008, 01:54 PM
  3. Impeller pumping backwards
    By linesix in forum Mercury Mariner Outboard Archive
    Last Post: 09-27-2006, 10:00 AM
  4. FUEL GAUGE RUNNING BACKWARDS
    By intrepid in forum Archive 2003-2007
    Last Post: 09-13-2006, 11:33 PM
  5. Backwards evinrude
    By benpowell in forum Johnson Evinrude Outboard Archive
    Last Post: 05-02-2003, 01:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
