Results 1 to 4 of 4
  1. #1
    Join Date
    Jan 2008
    Location
    Posts
    74
    Default "hi all-- I have a 1998 4.
    "hi all--
    I have a 1998 4.3l w/an aplha1 and the stern drive leaking lube out the vent hole. I have replaced the gasket and the plug. The seat appears clean, and I have scraped it down lightly with a small flathead screw driver. The plug tightens up well. The boat is winterized, covered, and sitting outside in the not too bad but still cold NC winter. Any suggestions would be appreciated. Thanks in advance!
    --chris"
  2. #2
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default Welcome Chris: You may have
    Welcome Chris:
    You may have an old "gray" gasket stuck in the screw seat of the OD. Take a box cutter or small sharp pointed object and carefully probe the outside edge of the gasket seat to remove old material. The gaskets are tough so don't be afraid to cut into the gasket. We've all had your problem.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  3. #3
    Join Date
    Jan 2008
    Location
    Posts
    74
    Default Guy-- Thanks for your advi
    Guy--
    Thanks for your advice. After alot of scraping i have finally gotten the leak to stop. I finally got to look really good at it in the light and saw that the entire seat was cover in black paint and gook. I scraped it down to the bare metal and finally got it to stop. Thanks again for the advice!
    --chris
  4. #4
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "Great Chris; happy boating!<[
    "Great Chris; happy boating!"
Similar Threads
  1. Alpha one lower unit leaking oil out the side vent
    By mrsmith35sg in forum Mercruiser Sterndrive Archive
    Last Post: 07-07-2009, 11:09 PM
  2. Magnet drain plug in the Vent hole
    By elgineddie in forum Mercruiser Sterndrive Archive
    Last Post: 07-28-2008, 06:29 PM
  3. Helicoil dropped into LU through upper vent hole
    By hawkeyetx1 in forum Johnson Evinrude Outboard Archive
    Last Post: 02-20-2008, 12:49 PM
  4. 2004 25hpoily substance coming out of vent hole lwr unit
    By Jeff D in forum Johnson Evinrude Outboard Archive
    Last Post: 10-04-2007, 09:48 PM
  5. 2006 Mercury 60 HP Outboard Gas leaking from vent hose
    By quickdraw in forum Mercury Mariner Outboard Archive
    Last Post: 07-30-2007, 07:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
