"When I got the boat the limit
"When I got the boat the limiter had been bypassed. I have since fixed this and adjusted the 3 wire trim sender so the limiter stops the drive at the trim and tilt points but I cant seem to get the trim gauge to work. It always reads that the drive is tilted up all the way. I have tested the gauge by grounding the signal post, the needle will then move freely to the down position.
I think the problem is in the black box (brain) that feeds the gauge. Is there a way to test this? If not does anyone know where I can get a used one?
Is there a way to bypass this box and wire the gauge "directly" to the sending unit on the leg?
Any help or thoughts would be greatly appreciated.
Thanks all.
Dave"
Thanks all.
Dave"
