Page 2 of 2 FirstFirst 12
Results 31 to 53 of 53
  1. #31
    Join Date
    Jun 2009
    Location
    Jacksoville, FL, USA
    Posts
    17
    Default great idea about removing the
    great idea about removing the prop. Is it a lot of trouble to pull the power head?
    Thanks for the reply
  2. #32
    Join Date
    May 2009
    Location
    Quartzsite, Az, usa
    Posts
    489
    Default "No trouble, but the gaskets c
    "No trouble, but the gaskets can be expensive, I've cut them from stock plastic asbestos sheet from Napa. Just takes a lot of time. Will send you the book."
  3. #33
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default "success, I removed the upper
    "success, I removed the upper pump housing, the impeller and the lower pump housing. I faced each of them off carefully with a flat file (I learned this trick with aluminum carbureator flanges on lawn mowers as a kid) and coated them with a sealer.
    I decided to splurge and enlarge (a couple drill sizes) the water feed holes in the side of the foot. They just seemed puney and the part of the housing that they are in is not a structural area.
    When I fired it up I had water every where, out the upper exhaust relief, out all sides of the powerhead gasket......lol, at least I have water. Also, I know exactly where the powerhead bolts are so now I can replace it. Thanks for the help and the manual is neat."
  4. #34
    Join Date
    May 2009
    Location
    Quartzsite, Az, usa
    Posts
    489
    Default "Glad you got her going. And t
    "Glad you got her going. And there is still some summer left.
    Sometimes that gasket under the power head will swell up and stop leaking on it's own. You might try tightening the bolts just a little while its running and see if the leaks stop.
    Glad the book helped. It's a little generic, but seems to cover most of the permutations of those many manufactures. My biggest hurtle was parts numbers -and most of those are Wards numbers as I had access to their micro fisch sheets. Even have a list- but as they are out of business, and micro- fisch is obsolete, I left them out. When I'm done, I'll get the finished book on the web site. But need more feed back and find out where are the errors and hard to understand parts."
  5. #35
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default "I took the power head off and
    "I took the power head off and cleaned up the plate and both surfaces. I couldn't find any high temp gasket sheets so I decided to us a gray colored permatex brand liquid sealer that has a tem rating of 650 degrees. I have used it as a gasket replacement before with good luck. So, in about 24 hours (cure time) I will report in with results"
  6. #36
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default "tested it early, couldn't
    "tested it early, couldn't wait.. no leaks, only leak was at the shifter shaft and I am not going to worry about that"
  7. #37
    Join Date
    May 2009
    Location
    Quartzsite, Az, usa
    Posts
    489
    Default Pretty common leak there. If y
    Pretty common leak there. If you get real bored you can remove the shaft and find a spot for an "O" ring seal with lots of grease.
  8. #38
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default "realllly bored....lol. Sorry
    "realllly bored....lol. Sorry gotta move to the next project, painting my daughter's room"
  9. #39
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default "want to hear a funny? I h
    I have a down syndrome son, he is a handfull and really likes to tinker. I got the little engine all tuned up and carb set, it was really pulling on the high end. So I took it and put it on the boat to do a real test. It dies in the middle of the pond, won't restart no matter what I do. I hand paddle back to the bank, set it up in the garbage can. I try everything, finally I pull the flywheel, thought I must have broke the key and lost the timing. Everything is ok. Put it back to gether. Getting ready to pull the reed valves when I noticed a little water in the edge of the carb......I pulled the float bowl and found water.
    I figure, pump the bulb a few times and clear out any water in the tank. A gallon later I realize my little helper had taken the garden hose and filled the gas tank....
    He has been watching me work on this thing so he knew it was really important....lol
    He pulls several stunts a day like this. It never gets dull at our house"
  10. #40
    Join Date
    May 2009
    Location
    Quartzsite, Az, usa
    Posts
    489
    Default Gee dad he was just trying to
    Gee dad he was just trying to be involved in what you were doing --the wet stuff goes in here ???Right?
    Those little guys are so much fun!
  11. #41
    Join Date
    May 2007
    Location
    Inverary, Ontario, Canada - The Great White North Eh!
    Posts
    9,127
    Default "Moral of the story - a good w
    "Moral of the story - a good water separating filter can even take care of the "unexpected" [img][/img]"
    Graham
    A "professional" is someone who gets paid for their work - it doesn't necessarily mean they are good at it :)
  12. #42
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default my little 7hp monty ward decid
    my little 7hp monty ward decided to get a hole in the brass fuel float.....have I read somewhere that I can go to a clinton lawn mower parts place and still get something like this. Or is Clinton a still going brand even?
  13. #43
    Join Date
    Jun 2009
    Location
    Posts
    17
    Default have had no luck finding a flo
    have had no luck finding a float that will fit and work in my 7 hp clinton M/W engine... any hints on how to cross referance or something?
  14. #44
    Join Date
    Jan 2007
    Location
    Edgerton, Minnesota,
    Posts
    327
    Default "You might try this link [url=
    "You might try this link http://discount-marine-parts.com/index.html But you need to know the carb model. If the hole isn't real big it could be fixed. Someone with soldering experience (a local plumber) maybe able to help."
  15. #45
    Join Date
    Sep 2012
    Location
    Portland OryGun
    Posts
    1
    Default Re: 7 HP Montgomery Ward Clinton
    Hi Folks, New member here... Ok A Monkey Wards (Clinton K 700) 7 hp always in forward gear. Seems like I saw some post on the web LATE last night talking about a busted shift spring. Looked for a owners/repair book but no luck there. Is the repair / parts worth it or should I have it sleep with the fishes? The unit looks about new and starts runs fine......Thanks in advance for your time,.........PJ.............
  16. #46
    Default Re: i have sea king pdf files for
    Could you email me those files please? [email protected]
    thank you very much!
  17. #47
    Any chance these PDF's can still be gotten? I have a Clinton Engine K7002106A Sea King.
  18. #48
    Hi,
    Sorry for multiple posting this, but Ditto to the manuals question for a k700.
    thanks
  19. #49
    Hello would you still have PDF files for MW sea king 7hp model K7002107a? I want to give a tune up. My email is [email protected]
    phil
  20. #50
    Quote Originally Posted by rontot View Post
    I have the Clinton 7hp 1972 K03107A, could use pdf manual for it.
    thanks
  21. #51
    Good afternoon, I just bought a 70's Clinton "Sea King" 7hp. Clinton plate says K700. Motor ran well when we started it up. 50:1 oil/gas mix. Ran a full throttle for the 1st 20 min. Fished a while, when I started the engine it would not run at full throttle, only at low RPM. Looking for advice.
    Would appreciate any manuals too. Thanks, CCF
  22. #52
    Default exRe: 7 HP Montgomery Ward Clinton
    Quote Originally Posted by ccf View Post
    I have a 72 k700 Clinton and if yours is air cooled llike mine, you need to stop using 2cycle outboard ooil and use chainsaw 2cycle oil at 24:1, mine runs great on that mixture. Been told that 50:1 will bog it down, give her a try.
  23. #53
    Hi. guys,
    This is Daniel from RUNLEDER in China.
    we have been specialized in R&D, manufacturing and marketing hour meter, tachometer for jet ski, outboard motor, ATV etc for 6 years.
    We have resettable tach/hour meter RL-HM032R for outboard motor as follows for your information.
    RL-HM032R Resettable tach/hour meter with engine service reminder,backlight and battery changable,display battery level. over speed alert.
    Are you interested in RL-HM032R for jet ski?
    Kind regards !
    Daniel
Similar Threads
  1. Montgomery Ward Sea King 1973 5 HP Clinton K500
    By technoid in forum Clinton Outboards
    Last Post: 01-02-2011, 04:52 PM
  2. Montgomery Ward Sea King 1973 5 HP Clinton K500
    By technoid in forum Montgomery Wards Sea King
    Last Post: 10-02-2009, 05:10 AM
  3. CLINTON IGNITION PROBLEMS 75 HP Sea King Montgomery Ward
    By bobbyg in forum Clinton Outboards
    Last Post: 06-25-2009, 10:15 PM
  4. Montgomery Ward Clinton Outboard
    By sdhardesty in forum Archive 2003-2009
    Last Post: 04-19-2008, 07:54 AM
  5. Montgomery Ward Seaking 75 HP Clinton Engine Help
    By jhnyutah in forum Archive 2003-2009
    Last Post: 03-30-2008, 11:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
