1989 43 OMC Cobra More power needed Please Help
snowbrder
I have a 17.5 foot 1989 Fiberk
I have a 17.5 foot 1989 Fiberking Commander with a 4.3 OMC Cobra. It has 175 hp. I would like to increase hp and torque. I would like to get hp to around 250. All help is greatly appreciated.
Thanks John
"The easiest way to get to 250
"The easiest way to get to 250 hp is upgrade to a 5.7. You can swap out the carb and manifold to a 4 bbl set-up.. This will put you at about 200. Other than that, there's not much else you can do economically and if you're willing to drop some real $$$, you might as well go with the V/8.
200 hp should put that boat at near 50 mph. What exactly were you looking for?"
There is not enough room for a
There is not enough room for a V/8. The boat does 53 with a 21 pitch prop. I'm looking for 60 to 65 mph.
"[b]"I'm looking for 6
""I'm looking for 60 to 65 mph."
Ayuh,..... That Ain't gonna Happen,...... Period....
You'd need to Double your available horsepower to get to 60/ 65mph.....
If that 175hp has a 2bbl. Carb,.....
Going to a 4bbl. Carb will net you about 20/ 30hp.....
That Might get you another mph or 2........"
"I dunno, I saw a boat of abou
"I dunno, I saw a boat of about the same type the other day doin' 65, not sure of the motor, but the trailer was REAL nice........."
"my other boat is a bayliner 1
"my other boat is a bayliner 1750 close to what u have with a older 250 mariner outboard 50+, to hit 60-65 with this boat I would need twin 250s to see that kind of speed. With out some big power 450-500hp min your never going to see 60-65mph."
