"New to this forum and I have
"New to this forum and I have a question regarding the high pressure fuel pump located inside the Vapor Separator Tank (VST). The pump
was frozen after sitting for 3 years on my counter rotating motor. I was finally able to get the pump to run, but there is no pressure.The final fuel filter was removed and cleaned, the pulse fuel pump was rebuilt and a new water seperating filter installed. Fuel is getting to the VST. The voltage to the Pump is the same as the battery voltage(12.58v). The pressure regulator test OK according to the service manual and the connection to the ECM harness test OK. Does anyone know if there are any other test I can run to verify that the pump
is bad before I have to spend $500+ on a new fuel pump. Thanks in advance for you help."
