Bellhousing intake water hose
"Pretty much Impossible withou
"Pretty much Impossible without Pulling the Bell...........
When Any 1 piece of Rubber goes Bad inside the Bellhousing,......
It's time to Pull it,+ Replace ALL of the Rubber Parts.........."
"well thats where i started wi
"well thats where i started with my boat, and listen do the bellows and shift cable when in there if not you will probably end up doing it again i have. If you can get the tool to remove the housing it will make it eaiser if its on top of transom like mine was. Make sure you get the clamps tight to nothing like seting at launch site putting the hose on again."
