Results 1 to 12 of 12
Thread: Bmw diesel
  1. #1
    Default I started the engine and I he
    I started the engine and I hear a sound (knock) from cylinder No2. Temperature is ok oil pressure ok no oil in the water.
    Any advice?
  2. #2
    Join Date
    Apr 2006
    Location
    , Langkawi, Malaysia
    Posts
    5,750
    Default "You did not mention which of
    "You did not mention which of the BMW's, but if it sounds like a hammer knock it is most likely a hanging injector."
  3. #3
    Default "Thanks for your prompt reply.
    "Thanks for your prompt reply. The model is D150, when you hanging injector what do you mean?
    Thanking you in advance."
  4. #4
    Join Date
    Apr 2006
    Location
    Posts
    5,750
    Default "The needle in the injector is
    "The needle in the injector is leaking fuel into the cylinder at too low pressure. Normally caused by water in fuel, or overheated injector due to lack of fuel. Sometimes it sorts itself out, but mostly the injector has to go to a Bosch service. You may change the nozzle itself providing You have a pressure tester and the corresponding specs, which I do not have."
  5. #5
    Default Thanks a lot Morten.
  6. #6
    Default "The problem was solved after
    "The problem was solved after your instructions very good thanks. Now we have another. Oil temperature is High 90 Deg C instead of 85 deg C, and also oil pressure low 2 bar. Could it be a blocked water radiator.
    thanking you in advance.
    Best Regards"
  7. #7
    Join Date
    Apr 2006
    Location
    Posts
    5,750
    Default "Oil temp of 90 C is low, and
    "Oil temp of 90 C is low, and not high. It should go to 110-130C.
    What might be interesting is the indicated change of both pressure and temp.
    Anyway if Your heat exchangers have never been cleaned and the boat has been used in salt water I would start by giving them an 'acid treatment'. There are two exchangers, the first one is for engine cooling water, the second is the oil cooler. Another problem might be the raw water supply and/or discharge. Worn impeller/pump or partly clogged exhaust riser. I do not know if You still have the original BMW exhaust riser, or the later VM cast iron riser."
  8. #8
    Default what acid treatment you sugges
    what acid treatment you suggest do know of any specific make?
  9. #9
    Join Date
    Apr 2006
    Location
    Posts
    5,750
    Default "There are two ways to go, pul
    "There are two ways to go, pull them out and send them to an auto radiator shop for cleaning, or go to a shop and ask if they have a couple of liters to sell. I used one from the cement industry that dissolved the chalk in cement, just left the sand! Great stuff, but dangerous!!!!! Be extreeeeeemly careful. Use rubber gloves. Get some extra hoses and attach to inn-let and outlet and fill the salt water part of the exchangers. Leave it for half an hour and flush with fresh water. Repeat the procedure. Do a test run."
  10. #10
    Join Date
    May 2008
    Location
    Split, Split, Croatia
    Posts
    1
    Default I am looking for a cylinder he
    I am looking for a cylinder head for BMW Marine D12. New or second handed. Does anyone have an information?
  11. #11
    Join Date
    Apr 2006
    Location
    Posts
    5,750
    Default Contact Hatz diesel in Germany
    Contact Hatz diesel in Germany or their closest representative. They are the ones hat made it.
    Just Google 'Hatz diesel'.
  12. #12
    steve bray's Avatar
    steve bray Guest
    Default "anyone know of a bmw marine e
    "anyone know of a bmw marine engine parts supplier in germany, if so could you let me have their contact details
    many thanks steve"
Similar Threads
  1. I have sighted a Detroit Diesel 451 Marine Diesel engine in Mobile AL
    By Daniel F. Blanchard in forum Detroit Diesel
    Last Post: 07-27-2016, 06:09 PM
  2. 4 stroke diesel engine vers a 2stroke diesel
    By john motta in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 03-20-2008, 01:16 PM
  3. 65L Diesel V8 Gas to Diesel Power and Easy Install Job
    By Ty/... Ct. in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 03-05-2008, 09:44 PM
  4. Has anyone tried Diesel 911 water in diesel
    By broggerp in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 10-03-2007, 04:46 PM
  5. Bad diesel
    By groundhog in forum Archive 2003-2007
    Last Post: 11-03-2006, 04:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
