1986 150 Blackmax no spark
merk1
"Have NO spark to ANY cylinder
"Have NO spark to ANY cylinder. Kill/Mercury switch check good. Disconnected Black/Yellow to Switchboxes, no help. Checked Rectifier, Stator and Trigger per Clymer manual. ALL READINGS (Resistance) check Good/EXACT per manual.
What other readings (maybe voltage) can I make to determine failure??
What are the MUST HAVES to produce spark??
Are there VOLTAGES to the Switchboxes/Stator/Trigger that are required??"
most likely the low speed wind
most likely the low speed winding burt out in stator need dva meter to reed voltages unit has 2 packs both rarely fail at same time
