"Is it normal for the splines
"Is it normal for the splines on the prop shaft on my Evinrude 1967 V4 60HP to be open at the front (forward gear) end and closed at the back (reverse gear) end? That is, the dog clutch will slide on from the front but not the back.
I'm asking because the thrust washer between the reverse gear and the spline end was flattened enough to be trapped in the groove (i.e. wouldn't move along shaft), which suggested a very heavy impact on the prop end of the shaft. This could have turned down the ends of the splines but it'd take an enormous impact on the prop end to flatten them and probably do more damage to the gearcase and shaft, so I suspect that the splines are machined that way.
It doesn't make any difference I can see to the operation of the dog clutch. About the only difference between forward and reverse would be that the lugs on the dog clutch are stopped fractionally before they hit the reverse thrust washer but they're still far enough in to engage reverse.
Thanks for any help."
